Dirtyl3um »
https://forums.nicoclub.com/dirtyl3um-u49427.html
Wed Dec 29, 2010 11:43 pm
Alright so im trying to figure out what on EARTH happened. Here goes....
So i bought a motor and transmission from this kid for 400 bucks and put it in my project car. I also put an exhaust cam from another car on the intake side to raise compression a bit. Ever since i got the car started it had this obnoxious noise that sounded like marbles under the valve cover. Since there are no chain guides ( i did a top end rebuild) i figured i just needed to shim the lifters and that they were the culprit as far as the noise was concerned. Today i measured all of the valve clearances and only 1 was out of spec, and it was only .001 off. I figured while i had it taken apart i would make sure everything was nice and to spec. Now all my intake clearances are .013 and my exhaust are .014. Tada. turned the motor over by hand and it all seemed like it was going well. I put everything back together and go to start it. When the motor turns over i still hear the marble noise. My battery was all but dead so i jumped the car and tried to start it another time or two. Then it clicks, like the motor is locked up. So i get out a ratchet to see if i can crank the motor by hand and no bueno. Its the weirdest thing ive ever seen because the motor will turn about halfway over, but there is a point counter clockwise, and clockwise where it will no longer rotate. I thought maybe somehow the cam slipped, or there was a sticky lifter so i detatched one cam sprocket and took the spark plugs out of the motor and still the same thing. Then i emptied the oil and there is NO metal in it whatsoever.... ?????????????
I have NO idea what the issue is, All i can think of is maybe the cam bearing is jammed at that point for some reason? maybe that was the marble noise, and now its just locked up? Any idead would be amazing
