engine overheating....why?
KwayKer
Car: 1991 Nissan 240SX Coupe
Hey,
My car ran fine then the alternator died. I replaced it, and now my car runs too hot. I took off the radiator hose to have easier access to the alternator, but I put it back on and there are no leaks. Does anyone have a clue what this could be?
Matt
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
Did you bleed the coolant lines after replacing the hose? Air pockets in the coolant can easily create overheating problems.
KwayKer
no i didnt....how do I bleed coolant lines?
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
I assume you refilled the radiator to capacity after you hooked it all back up? Did you check you radiator cap? Maine is right, but I've never heard about bleeding coolant lines.
red240ne
Car: mmm...donuts
yes, there's a bleeder screw around where the upper radiator hose goes toward the intake manifold.
Repo Man
2003 Honda Accord
red240ne wrote:yes, there's a bleeder screw around where the upper radiator hose goes toward the intake manifold.
Damn, learn something new every day! :D
MaineExport
Ayah!
(that's Maine-talk meaning, "yes")
KwayKer
first....bleeder screw = 10 mm bolt to the right of where the raditor hose connects to intake manifold?
second...just unscrew it to release all air, or what is the procedure?
Thanks!
Matt
red240ne
Car: mmm...donuts
yea, just unscrew it. i think it's 10mm. it's pretty small. i just remember that it's a ***** to reach.
bruinbear714
if you have the ka24de engine, the screw is out in plain view and you can open it using a 10mm socket. Unscrew it completely, fill up your radiator with coolant, turn on your engine, and fill up the radiator some more until coolant starts spilling out of that hole. Cap it up and take it for a spin.
Make sure your car is level AND that the engine is cold. If it overheats after that, then you might want to replace your thermostat.
MaineExport
And if it still overheats after a new thermostat..... try testing the thermostat!!! My recent overheating dilemma would have been significantly less expensive had I tested the new one first.
KwayKer
I followed all the instructions on replies, and engine temp has returned to normal. Thanks to everyone who replied, this forum rocks!
Matt
Stock-S13
ok after looking at the manual i couldt get to these two pulgs. maybe cuz i dont have jacks or stans anyway, they are the drain plug(not the one on the radiator but one on the block left side) and air release plug as well any help is appreciated.thanx
Anand
I get the air out the old fashion way.. once I fill it up just keep the cap off the radiator and start her up.. the ait pocktes will come out on their own.. I learned that while working at a shop a while ago as a summer job.
