TheOne »
https://forums.nicoclub.com/theone-u18820.html
Sat Mar 04, 2006 10:11 pm
ok, first things first, its a 95 nissan 240sx, its got 170k miles.
what happened: goin down the highway the heater hose that goes from the block(on the back, down of the intake manifold to a tube), got a hole on it from a shop that did a bad install of the hose(over tightened the clamp), and well enough coolant got out of it and overheated the engine till past the H, when we went to coast it, it was put on neutral and the engine stalled.
what we've fixed(the owner of the car and i), we replaced the water pump cause it started leakin, we replaced the hose that leaked in the first place, we also replaced the spark plugs & wires(the plastic down where it meets the spark plug melted on all 4 of'em), the oil cause it smelled cooked, the thermostat, and we flushed the coolant.we did a compression test and numbers came out(compression done with instructions from FSM, car warmed up)#1 - 160#2 - 170#3 - 170#4 - 170
while we replaced the water pump, we also wired the A/C fan to work with ignition(1 of the how-to's in 240sx.org install page), and so we removed the mech fan and fan shroud.
now the problem: after 15 mins of the car idling(this is after warmed up, normal temp, so maybe add another 3-5mins), it will start to overheat, the fan kicks into hi mode, and it tries to get the temp back to normal, but it just doesn't.
what am askin is, could it be the headgasket?, or just that there may still be some air bubbles in the coolin system?compression is not really tellin us that it could be that, we also did our best to bleed out all the air from the coolin system.
ps. there is no smoke comin out of the exhaust and from what we could see of the pistons, there is no coolant in there.
sry if this may seem long, but i had to describe in detail to get a better answer.
