itsa300zx wrote: ↑Sat Apr 04, 2020 9:56 am
Personally, I would helicoil, will be stronger if done properly. Just be sure it is straight (normal to the surface) as possible.
Alright. I got my Helicoil kit, M10 x 1.5.....Screwed up again (no pun intended). So being anxious to finish this thing, I followed instructions of the Helicoil kit. I used a 13/32 drill; worked fine. Now was the stupid part. I naively thought the tap would go in straight. Boy was I wrong.
So I thread in the Helicoil flush with the surface, and I realize it's crooked....So I Google "crooked Helicoil." People say that if a "turn is out" you can use needle nose pliers and go counter clockwise. I was lucky and did that to pull out the Helicoil.
Now, I have no choice but to drill the 13/32 all the way to the end of the hole, and I do so. So the second time around, I got my old upper idler and tap it through the hole. Wasn't much effort, just a couple minutes and I did it. So now, I get the old idler and make sure I push it up against engine so that there's no tapping in crooked....It worked. However, now the new Helicoil sits in the last half of the newly tapped hole. When I screwed in the stud and new idler, I used my Milwaukee impact wrench (3/8th one) to no. 2 torque setting.....It's spinning, and now my heart dropped. I thought I stripped it. But I remove the new idler and the stud, look inside but the Helicoil threads are fine; no stripping. My question is, since it spins whenever I tighten it should I just use Loctite on both ends of the thread. I used a torque wrench and set it to 32 lbs. but it kept spinning. I'm really afraid of doing more damage.
