ditto.2cv wrote:i noticed these things too and i think it helps to drive slower and smoother
fairges wrote:I have encountered a similar noise - my Rogue has about 3500 miles. It almost appears that the gears are trying to catch up- that type of noise. It doesn't happen if I switch to manual transmission.
Is it the CVT and it works differently than a nomal transmission?
Couz, that's not a rattle. The Rogue CVT deliberately shifts into high gear for better fuel economy. This results in a bit of vibration similar to driving a manual transmission vehicle in very high gear at low speeds. This is completely normal and has been well documented about in these forums.Couz wrote: That's exactly what I hear, that rattle that you get when you your gears are too high for the speed your at.
The transmission noise discussed elsewhere on this forum sounds similar to shaking a paper cup full of marbles... or for you gamblers out there... a shaker cup with dice.
the sound appears when the car is in that vibration mode....as was mentioned its the sound that is similar to when a manual transmission is in too high a gear and you give it a big push of gas to pick it up or catch the gear....it happens rarely.philipa_240sx wrote:The rattle sound is generally heard at parking lot speeds (<10 km/h). It's higher pitched.
Sounds like you are getting a different noise, especially if it's at higher speeds. If in doubt, take it to the dealer to have it checked.
