mrodrig2 »
https://forums.nicoclub.com/mrodrig2-u106864.html
Thu Aug 26, 2010 10:09 pm
You should stick to the manufacturer's recommendation unless you live in an area that tends to have one-sided weather or hits either of the extremes often. Only then should you think about going up or down in engine oil viscosity.
If it never goes below freezing in winter and is very hot in summer then you can think about going 5W-40, 10W-30 or 10W-40. If it only gets moderately warm in summer and often goes below freezing in winter, then you can think about going 0W-30. If your region is temperate, don't bother with anything other than the recommended 5W-30.
