engine oil smell like gasoline ....
LOVERboy
Car: 1997 240sx se KAT
aite guys ... first off, It's a KA-T. mods on the engine are; t28, 370cc injectors, N62 mafs and tune with apexi safc.
so after i put the N62 mafs in, i start playing with the safc. Today I checked the dip stick and the oil drip like water ..... and it smell like gasoline....
does that mean I blew my head gasket or something?
T_____T
ashibah83
Car: 93 SUPA BLACK COUPE
piston rings......im willing to bet that your getting blow-by like a mother
LOVERboy
what is a blow-by?
ZOMG.SR20
Car: 1990 s13
you need new piston rings now
blow by is the air-fuel mix blowing by your piston rings and in to the crankcase
LOVERboy
aite sooo ... imma need a new piston rings .... is that it? or should i change anything else too?
ashibah83
LOVERboy wrote:what is a blow-by?
.........uhhhhhhhh..............small amounts of oil passing by your piston rings(due to wear and a pressurized crankcase), being burnt in your combustion chamber, it may allow gasoline to leak past your rings and into your oil
might as well check all your bearings while you have the rotating assembly out, and a head gasket wouldnt be a bad idea either
LOVERboy
grrrrr ..... okay .... thanks guys =)
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
time for a rebuild
LOVERboy
yup!!!! sigh ... well I guess I wont be driving my car for couple months then .....
T______________________________T
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
before you park your car because we on the forums told you to i would check your compression at the least. Or do a leakdown test that will really tell you what the condition of the engine is.
your oil maybe gasy, but change it out and see if it comes back. Maybe you were just running really rich for a while when u were tuning the SAFC.
do you know what a compression and leakdown test is? If not, http://www.google.com will tell you
Marko
LOVERboy
okay! =) thank you! =)
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
EstoMax wrote:before you park your car because we on the forums told you to i would check your compression at the least. Or do a leakdown test that will really tell you what the condition of the engine is.
Marko
Nice esto, I agree always check compression, if it is bad then its time for a rebuild or replacement.
KFL
Car: S14
Marko
Also a very common issue is a fuel injector oring failure..sometimes gets pinched and leaks. With fuel rail off turn key to acc, if any fuel squirts through oring fail.
assassin7420
Car: 1996 Nissan Silvia
1995 Nissan 240sx (daily)
Just because his oil smells like gas does not mean the engine is bad..... Good god.
If he runs rich, Guess what... Oils going to have some gas in it. It could be a NUMBER of things that are very simple.
1KleenS13
Definatly a leakdown test. Like was said, A pig rich AF mixture is going to wash the cylinder walls down and you will have gas in the oil.
LOVERboy
and for leakdown test ... how long do I have to wait to see if the compression leaks or not .... ?
LOVERboy
okay I just finished the compression/leakdown test anddd none of them leak but cyl 1 only get 135psi max ... the rest are between 150-159psi. .... so does that mean i still should change piston ring or no??? will it be okay to drive around like that?
kc240guy
Car: gold s13 and a maxima
If you're getting blow by your valve cover vent tube (forgot the name) will be putting out a lot of oil into your catch can if you have one or wherever else its connected to. 135 is pretty low and only gets worse with time, especially with boost. If this is what's causing gas in the oil I'd be a little afraid of losing lubrication in vital places.
1KleenS13
LOVERboy wrote:okay I just finished the compression/leakdown test anddd none of them leak but cyl 1 only get 135psi max ... the rest are between 150-159psi. .... so does that mean i still should change piston ring or no??? will it be okay to drive around like that?
Put a couple of drops of oil in there and see if it goes up, If it does the rings are worn.
LOVERboy
only cyl 1 gets better compression with oil. but it only went up 3 psi .....
Gcustoms
Car: 1992 240sx LE
piston rings, if you blew the head gasket youd either be burning antifreeze, leaking oil out, leaking antifreeze out, or in the pontiac sunfires case, all 3. its the rings sorry to say.
LOVERboy
Will it be okay to run like this for now?
1KleenS13
LOVERboy wrote:Will it be okay to run like this for now?
I wouldnt, your going to be sending gas into your oil, then the gas gets into the bearings. You might just be making a bigger problem later on down the line.
RedSubdivisions
Car: 1989 BMW 325i, 2002 BMW 330i
I've had the same exact thing happen to me when I turbocharged my KA. Except I was running 555cc's, using a BikiROM, and trying to use a SAFC and that made my car pretty much dump a ton of fuel into my cylinders.
Your rings are shot. When I took mine out, they were pretty worn and my oil just absolutely reaked of oil. At that point, I knew my motor was ready for a rebuild.
It's not hard, but it's also not the easiest thing to do in the world. Anything worth having takes work and I bet if you rebuild that motor and clean it up really nice, you'll have a brand new KA that will kick some serious a**. When I put my new rings in, my compression on all 4 cylinders was over 200psi. I was pretty happy when I saw that and my car had an amazing response after that rebuild.
ZOMG.SR20
Car: 1990 s13
your oil smelt like oil....... did i miss something
Papi Chulo
Car: 72' Datsun 510
my oil smells like cheese
ZOMG.SR20
Car: 1990 s13
^ and Vaseline right...
RedSubdivisions
ZOMG.SR20 wrote:your oil smelt like oil....... did i miss something
Oops. Meant to say oil reaked of gas. Sorry, I wrote this when I was zombified at work....
93240cooool
Car: 1993 240sx
Papi Chulo wrote:my oil smells like cheese
OMG!!!same!!
it makes me a want a hamburger real bad.
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
you could just have a leaky injectors or something...like an injector O-ring going out...any ecu codes?
do a compression check and leakdown test...if compression or the latter are bad...rebuild time
my oil always smells like gas a little bit...Im running a real motor though, not a KA-T
bwwwwaaaahahahahahahahahaha
SR is always > KA-T
booooyaaa
