Hawairish wrote:So it's not cranking at all? Or does it crank and not start?
When attempting to start, do the dash lights dim, flash, and click?
What was the voltage on the portable battery?
Have you tried a traditional jumpstart after letting the battery charge a little?
No cranking at all.
Yes dash lights dim/flash, and I hear a relay (?) click in the dash.
Not sure what the voltage was on the portable battery.
I actually took the battery in yesterday and they charged it up for me. I put it back in, and it behaves just as it did with the portable battery (turning the key turns on the dash lights, they dim, flash, and click when turning all the way, but no turn over).
Upgrayedd wrote:Did you replace the battery?
Nope -- but (correct me if I'm wrong) if it was the battery, then it should've started up just fine with the portable battery right?
As mentioned above I took it in to my shop and had them charge it -- and it still doesn't turn over. It does appear to be holding a charge though...
Thanks all
