engine not starting
cosmic22
hi, hopefully you guys can help. I have a 97 240sx and was installing a msd6al on it. I messed up the install and blew a fusible link. I replaced itand decided to put back the stock wires. I did extend the stock wires with14 gauge wires..much thicker..but now the car won't start..it tries to..butslows down..like gugh..gugh.........gugh..gugh.. and so on..i did a batteryvoltage test..and when i tried to start it...it drops to 9.5 or so..i'm notsure what could have been affected when i blew that fuse..the computer hasno check engine light or and problems whatsoever..i'm wondering if thecircuitry of the starter could have been messed up from that surge andblowing the fusible link...battter is full..can't pop start the car..don'tknow what to do..except look at the starter..and it started perfectly beforethe msd..and i have reset the comp already many times..thanks for youtime
AVERAGE
Car: 1987 Nissan Sentra
have u checked all ur fusible links. maybe there was more than just one on the same circuit.......or maybe u just blew 2 at the same time. hope this helped
cosmic22
all fusible links are fine..what is the difference between cranking and turning over?
cosmic22
also..i tried to pop start it..and it still didn't start up..so..i'm wondering why i can't start it manually? any ideas?
