maxnix wrote:Hopefully you will pull and steam clean the tank this time since you know it is dirty, change your fuel filter and rinse your lines.
And only buy fuel from new Tier 1 stations!
I don't think there is anyway to steam clean tank with all the baffles inside but it should be pretty clean now. Maybe I should filter the gas before I put it in the tank?
QUOTE=maxnix]So you had both the injection rail service and intake fogging done?
Change fuel and air filters once per year. X that service station that dispenses mud.
Fuel rail hose clamps are best done with plenum off if clamps not oriented perfectly. How did you replace these hoses without removing the plenum?
[/QUOTE]
I previously cleaned the intake manually as noted above. Used about half a dozen cans of carb cleaner. However, I do have about 10 cans of BG air intake cleaner which I have never used.
Fuel hoses looked good on 95 Q (with only about 80k miles) and it has never had a fuel leak that I know of. I was able to tighten rear clamps by tightening with short stubby screwdriver-just in case.
I did replace fuel hose on my 1990 recently with viton lined hose. Is that what IOS sells?
