Engine not kicking in at 1000 rpm until it hits around 3 to 4 rpms please help
djminus
Car: 1991 Nissan 240sx
So this is the situation, I took care of all the exhaust leaks on the piping and I put new spark plugs in my KA24 engine and I still have some problem on take off on 1st gear and I gas this ***** and it still takes its time to just go. after it hits a certain point it rises up to what the engine should be doing. please help me because I am running out of ideas on what it can be PLEASE!!
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
the details are a little vague, but from what im making out, it sounds like a clutch.
djminus
well if it is the clutch wouldnt I hear something rub or somethin along that way. Uhm I mean itll start pulling after a certain rpm yea but if it is the clutch cuz someone else did mention that as well but I cant really hear anything rub if that.
djminus
could it be my output shaft maybe??? ionno Im trying to think of the possibilities I can look into before doing any major fixes shes almost its just there's something not beign right on that particular part at take off on 1st gear.
jdm_master_X
well the reason i believe it to be the clutch is because when a clutch is slipping it takes a lot of RPM to get the car moving before it RPM and vehicle finally catch up.
gumby74
If it is the clutch, more than likely it is, adjusting the clutch pedal might buy you a little time.
mould_jesus
Car: 1996 200SX SE-R (RIP). now a 1995 240SX
it's the clutch.
you normally won't hear it rubbing. you don't hear it rub when it engages on a good clutch. when the clutch goes bad all it means is that it's worn out. it's not really a problem or anything... just periodic maintenance for every 90k miles or so (or however long the clutch is rated to go for).
djminus
thanx people of nicoclub its THIS CLOSE FOR HER TO GET MOVING AGAIN lol does anyone know how to flush out the transmission fluid cuz mine is all black yikes!
djminus
oops I meant clutch fluid the one by the break fluid part
djminus
*bump* my buddie told me to check my clutch fluid and damn it was like really low and it was like black so I added new fluid but it came up black so should I keep rinsing it out with a siringe until it clears up maybe thats whats been going on this whole time possibly or would you still say the clutch is still a little loose
jdm_master_X
best way to clear out the fluid is to flush it. its like bleeding brakes.
djminus
and how do you do that... yea sry im such a noob... and I need to bleed my breaks too...
jdm_master_X
to bleed your clutch, i would suggest lifting up the passenger side of the front. on the transmission you will see your slave cylinder held on by two bolts on the transmission. on the slave you will see a bleeder. open up the bleeder with either an 8 or 10mm wrench. once fluid starts to leak out of the bleeder screw, close the bleeder. have a friend pump the clutch deeply 3 times and then have the pedal held down on the third pump. while held down, open the bleeder, let the fluid stream come out for about a second, and then close it. repeat this process until the clutch fluid is clear and the pedal feel is fine. refill the clutch master cylinder as necessary.
