Engine not geting gas!
S13difta
Car: White SR S13 vert!!!
I have a stock ka24de and when I try to start it sometimes there seem to be a problem with the engine getting gas I've replaced the filter pump and regulator and still the problem prestists I think it's related to the evap systmem but not sure how to diagnose that?
costa_rican13
Car: 1993 s13 coupe
your injectors can be clogged as well. unlikely all 4 would go at once, but like everything, it is possible. are you sure your pump is pumping as well?
S13difta
Yea the pump is good we took it out and tried it while it was out and it was working and the injectors where not showin signs of going out but your right you never know we did take off one of the fuel lines at one point and there was no gas the came out when it normally would
jazz4890
Car: 1991 Nissan 240sx
Check under the car along the passenger side frame rail and see if any of the hardlines are kinked thats what could be causing the gas to not go to the fuel line if your fuel pump is working like you say. Also check the rubber fuel line that goes to the bottom of your fuel filter to see if there is gas coming out of that hose if there is then check your fuel rail and your injectors for clogging you should check your fuel pressure regulator as well.
S13difta
Ok I'll look today and post what I find thanks for the help
