Need some opinions here. I recently did a chain guide replacement on a '91 Q with 122k and now the engine doesn't sound right. Here's a recording (5MB):
http://home.socal.rr.com/robverna/enginesound.mpg
I removed all the belts before recording that to isolate the sound as much as possible. No idlers or components, just crankshaft, pistons, valvetrain, and injectors. The sound seems to be coming from the left head. Here's the complete story: While doing the job the cords I had tied to the timing chain gave and the engine jumped time while I was doing the left bank. It was so quick, I wasn't sure what had happened, so I turned the crankshaft by hand to be certain. I felt the piston hit the valves, and I knew I had a problem.I informed Dave, the owner, and he decided to go ahead and have both chains replaced since I had to open up one cover anyway and because both valve covers were leaking. So in the end, I replaced all chains, tensioners and guides.Initially, I thought the noisy engine was because of the new guides needing to wear in, but now it's been a few hundred miles. I've changed the oil 2x since the job, along with mobil1 ATF flush, and I'm running 10W30 Mobil1 right now.I thought maybe I bent a valve when I did the hand check, but my shop instructor at school, who is an ASE Master Tech with 19 years experience, is certain I didn't. He listened to the car too but wasn't sure what the problem could be. He recommended I go to 0W30 oil, but I'm skeptical that'll help enough.The compression is fairly balanced:8: 148psi 7: 158psi6: 155psi 5: 158psi4: 155psi 3: 155psi2: 162psi 1: 155psi
I think I dripped a bit of Mobil1 into the #2 plug hole, which might explain the higher value there. I've ordered an oil pressure gauge, but haven't got it yet. In the meantime, no oil warning lights, and I have retorqued the main crankshaft bolt a 2nd time and I'm now pretty sure it is to spec.
I will get an oil pressure reading before doing anything else, but I wanted to throw this out there and get some opinions first. I won't hesitate to pull the cover again, but I would like to have some ideas about what to look for. Collapsed lifters? Bent rockers? I don't think the manual gives any gap measurements between the cam and rockers or did I just miss that?Thanks for any help.
