p00t »
https://forums.nicoclub.com/p00t-u5026.html
Tue Sep 16, 2003 1:22 pm
rattling for a breif time when you first start it up is ok, as long as it isnt rediculously loud. its from the chain picking up slack when you first start the engine, this does indicate that your tensioners are getting worn, but i wouldnt run out and spend $$$ right away.
They design chains to last the life of the car but it doesnt really work out that way. Chain and tensioners should be serviced every 100-130k if you wanna be safe, depending on the condition of your motor, and how much you care about your motor.
There are the lucky and unlucky... some people do have chain problems under 100k... and that just sucks.
