Engine noise when engine is cold
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
conversation
Car: Versa 1.8 S HB
On my 2009 V hatch 1.8, I get the "piston slap" only after total warmup. And it is louder inside the car. Sometimes I can't hear it outside at all, but quite clearly inside. Sometimes it is so bad the car seems like it is missing on one cylinder. The missing only happens at a certain stopsign, on the way home from work. Only happens once a month or so ( the missing).
The piston slap just about always happens once I've been driving the car for 15 minutes.
I'll never be able to get it to miss at the dealer though.
ANother weird thing : If I shut it off for 2 minutes and start it up again, the piston slap is gone.
pingflood
Mine's been doing it since I got it but has gotten worse since and at this point is it sitting at a dealer where they are tearing it down to investigate the cause.
lexluther
Car: 2009 versa
Just had mine replaced 27000miles 2&3 cylinder problems and blowby. THEY have an issue. I drove a cube while they repaired mine It sounded as bad w/37000 miles. Nissan corp contacted me i will talk to them on monday.
Don't delay going to the dealer!
TommyV8
Car: 2011 Nissan Versa 1.8S hatch
My Camaro has had piston slap when cold since it was new. Sometimes it can be so loud that people think I have a rod knocking. It goes away after the car warms up. 213k miles so far and it runs great.
I had a 1983 Celica with a 2.2 and it had a similar ticking sound all the time, not just when cold. It ran just fine with a ton of miles on it.
Jus14 wrote:I also had that type of noise then switched to 87 octane from 93 and its very faint now even if you hear it at all...
Putting 93 octane into an engine that only requires 87 does absolutely nothing except waste money.
Return to “Versa Technical Discussions”
