Engine noise
g109rogue
Hi guys,
My 09 rogue (335,700 km) starts to make this noise quite often, the noise is on and off.
here is the link: https://www.youtube.com/watch?v=TWr-eNGT3vk
Thank you for any advice.
Take care and stay safe.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
My first guess would be a crappy overrunning clutch on your alternator. Try removing the drive belt and see if the noise stops.
g109rogue
VStar650CL wrote:
Sun Feb 06, 2022 10:56 am
Hi VStar650CL,
Thanks so much for your reply. I just checked the oil and the oil level was low. After adding 1 liter, the knocking noise has gone but the other one which you mentioned from alternator is still there. I uploaded another video, the noise seems to come from either alternator or ac compressor.
Thanks again.
VStar650CL
Technical Expert
You're most welcome. Easy to isolate compressor noise, just turn it on and off and see if the noise changes. Depending whether it's in the clutch or the compressor itself, it will either quit or change in some way when the compressor runs. If it's the alternator or some other rotating component, then messing with the A/C won't change anything.
nands7
I had similar issue on my 2010 not this noisy though, it was coming from burnt clutch due to age.
You could eliminate Alternator bearing noise easily by placing chassis ear/stethoscope or tip of flat screwdriver and listen carefully.
Hope it helps...
g109rogue
Thank you for all the replies. I went in a shop and got the car checked, the noise is from AC compressor :chuckle:
I guess it is the time to test my DIY skills!
Thanks again and please take care.
Return to “Rogue Forum”
