Engine noise
CaDet s13
Car: S13 240sx
Powered by Ca18Det
https://www.youtube.com/watch?v=-QfhBOA ... ata_player
Ok, so thats a video of the noise i am talking about. Im not exactly sure as to what it is, but im worried it could be something serious if left unchecked. The car still idles fine and it wont make the noise until i start to rev it. It also drives fine with as far as i can tell no loss of power, seems to run like it was before that noise started up. So if anyone has experienced or knows what could be causing this to happen please let me know.
thanks, Shane
themadscientist
Whatever you recorded it with is overwhelmed by the volume of the engine noise so it's a little hard to be completely sure, but that sounds like a really bad rod knock. If it is you should not run that engine anymore. At best you are out a rod, but more likely the cranked is f*** too. Keep revving it and you will turn it into an air-cooled engine through the huge hole you blow through the block.
CaDet s13
Car: S13 240sx
Powered by Ca18Det
Ya i recorded it on my phone so i know its not the best quality video. I also know i shouldnt be revving it like that i just did it for the sake of the video since it only makes the noise when it is being revved. Im hoping its not the rod or crank. The noise itself actually sounds like its coming from my head but as u said it is hard to tell and me lacking experience on diagnosing problems doesnt help either.
themadscientist
You can normally tell the difference. A rod will sound like a rapid attack by a ballpeen hammer. Lifters sound like a drum solo with two 10mm bolts.
Izento
Car: RPS13
Sounds nastier than mine.
This is very much what mine sounds like. https://www.youtube.com/watch?v=V9eLMThlBZI
Not my video, but the sounds are very spot on.
CaDet s13
Car: S13 240sx
Powered by Ca18Det
Alright so its time for another motorset or or a bottom end rebuild which will most likly cost the same amount as the motorset
Izento
Car: RPS13
Why not build it then since they will cost the same? Lol.
CaDet s13
Car: S13 240sx
Powered by Ca18Det
Well that would be the plan but the problem is its my daily driver so i dont really have the time to build it. I do have a spare ca already but its nowhere near ready to go into the car and thats the one im trying to build.. So now im in a s*** position
boost_boy
Classic CA18 #2 or #3 rod knock. Keep revving it and you're going to ruin the crank. It was in the pre-cank runi stages, but no telling how long you've been playing with it. Again, the bottom end is need of servicing before a rod finds its way out of that cast iron block ;).
boost_boy
Izento wrote:Sounds nastier than mine.
The crank is this video is still salvageable at this point. The OP's video tells me the crank is need of cutting and being re-fitted for over-sized bearings.
CaDet s13
Car: S13 240sx
Powered by Ca18Det
Well that video is the only time i have ran it since the noise started so hopefully the damage isnt as severe as it can be. But i wont beable to tell until i tear it apart
boost_boy
All depends on what you were doing before you heard the noise. If you're doing 8000rpm clutch dumps, yeah, that crank will need to be machined. If you were in full boost and riding hard, yeah, that crank will need to be machined. All in all, it sounded pretty nasty, but let's hope you didn't damage it too bad.
Izento
Car: RPS13
CaDet s13 wrote: its my daily driver
The best part you can buy for your s13 is another DD.
themadscientist
Oh, the humanity! Such a terrible noise.
Izento
Car: RPS13
Speaking of rod knock, my mechanic recommended a remedy and I would like your guys' opinion.
He recommended welding up my oil bypass and running a racing oil filter (Canton) and getting rid of the oil cooler as it may contain metal now. With all of this, doing an oil change, attaching magnets to my oil pan and filter, driving it around for 300 miles or so and then get the bearings changed would be the most cost effective. Of course, he didn't guarantee it would 100% work, but the magnets should do a good job of getting metal shavings.
Does this sounds something wise to drive an engine with rod knock for 300 miles? I would figure a oil flush (with actual oil) and adequate idling would be enough with my Canton filter/ magnets as well.
Btw, don't mean to thread jack, but I feel it's pretty related.
float_6969
Sounds pretty shady to me....
boost_boy
That's just plain suicide, my friend. You're going to screw-up more than you can afford to fix. I wouldn't drive it while it's knocking if I were you.
themadscientist
No cheepo way to fix it. Rebuild is in order and you need to flush every oil passage to get the metal chunks out. I would weigh that guy's advice accordingly, it's alarmingly bad on this item.
boost_boy
If you have a factory oil cooler, you should keep it.
Izento
Car: RPS13
It's not the factory oil cooler, but it is only $60 for another core and I'll just reuse my lines.
But thanks for the info guys, I kind of thought it was a dumb idea to drive it with rod knock. And to think I was just about to do that today, lol. Luckily I have only idled the car and drove it off the tow truck to it's garage.
Well, time to let it chill and save up for a rebuild. Since I am sure the crank will need to be removed, I'll save up for pistons.
CaDet s13
Car: S13 240sx
Powered by Ca18Det
Hey Dee you wouldnt happen to have a spare ca set you want to get rid of do you? I have decided to bite th bullet and just swap in another and place this motor next to my other project one and slowly work on it when i have the time. If you do have one that would be awesome since we both live in south florida id beable to come pick it up. If you have one any place any of you guys know i can go through to get one would be appreciated
boost_boy
They are all rebuilt. Don't know how much you're looking to spend, but I'm not overly expensive. Basically, you'll get what you pay for.
CaDet s13
Car: S13 240sx
Powered by Ca18Det
I trust your work and im sure your prices will be fair. So let me know what you have and how much your asking.
boost_boy
I have one nearly completed. If you just want the long block, let me know and we'll take this to PM and discuss it further.
