engine mounts?
saeedakobiakov
Car: 03 M45
Hello,How would i know if engine mount have gone bad?03 m45 with 80k on it.Thanks,Caug
tigerclaws1318
Car: 2006 M45 Sport
Have the car on a lift just enough where you have the wheels off the ground. Put the car in drive with your left foot on the brake and give it some gas. With the hood open that way you'll be able to see how much the engine is flexing on its mounts. Shift it into reverse and do the same thing. If theres excessive movement going on then you'll know one or more of its mounts is going bad.
saeedakobiakov
Car: 03 M45
Thanks man. i will try that.
