engine mounts
asssmaster
Car: im running on hopes and dreams
i just bought a 1989 240sx and when it starts the engine wobles i know its the mounts but how hard is it to take out and replace? what do i need to do it? and what should i look for
180fan
Car: 89 fastback
Surprisingly not all that difficult...if the nuts want to cooperate and with the proper tools.
zerothread?id=215418
I'd recommend doing one side at a time instead of dropping the full crossmember. Also remember to hose down the 14mm nuts with some penetrating lube like PB Blaster or Triflo. If those nuts are stuck, they can be a real pita to deal with.
