centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Tue May 10, 2016 11:54 am
I've sprayed these with PB Blaster and then waited 24 hours. Then I put a flared crows foot on them, then extension, then breaker bar. The crows foot helps move the pivot point off to the side.
For cutting, if you have one, I would try a roto-zip type tool, with a cutting drill bit on it... I think. I don't know if it will fit, but in my head I would just put the drill up next to the nut and start cutting through it's side, towards the bolt.
