Engine mounts KA SR height measurement info
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
After my search for engine mounts (KA/SR) during my last swap I ended up collecting data on the different brands available, including dimensions. These measurements were provided by a helpful sponsor which will remain unidentified. He had all 3 sets in front of him and with caliper in hand was courteous enough to provide me with some numbers:
DEA mounts: 70mm
Nismo: 73mm and 74mm each one.
MEGANS: 66mm
The Megans were a "good" 1/4 of an inch shorter than the Nismo.
The Nismos being the thicker ones, while providing the unfamous 'gansta lean" that some of you know. They are higher quality and a must buy, but only, if dont mind loosing your strut bar and/or cutting your hood in some cases.... :dblthumb:
* This measurement is the length between contact surfaces of the mount.
