Engine mods
kilipo4
Car: scuba diving, hunting, cars, women, drunkenness
A while back I came across this site:http://www.racetep.com/240sxna.html
I've heard some bad things about the company itself (ie. not responding, taking way too long, getting s13 & s14s confused, etc) so I'm not sure that I care to deal with them. However, the setup still looks tempting. I wanted to get some opinions on it. Is it missing anything, will it be reliable, what's a good price for the work, any places in austin/lubbock that you can recommend, etc, etc.
My goal in the end is to get as much as I can out of my engine in naturally aspirated form. Then, when I'm no longer satisfied with that, I'll switch to lower compression pistons, new cams and re-port the head and go with a turbo.
Thanks for the :help -Cliff
RWDnot RICE
Car: 1995 Nissan 240sx SE
Man that is just as much money as an n-sport turbo kit?
actually more..?and a turbo if run at a low boost is not that unreliable..?(plenty of vehicles are already on the road sold stock with a turbo and run for hundreds of thousands of miles, it's when you get bored and start cranking the boost that you can casue problems)
http://www.gtpro.com/
http://www.rollhard.com/nsport.htm
Daunttless
Well yes, but at the same time many people like to pursue Naturally Aspirated power. I think Spoon would enlighten you as to the value of natural aspiration. : ) I think its cool, however you want to build your engine is great, just so long as you build it. : )
I can't remember what engine you ahve offhand Kilipo, but if you have a DE its pretty easy to boost the compression and what not, with normal upgrades, I/H/E and higher compression you'll be putting out enough power to be satisfying. Not a ton mind you, but enough to satisfy. Do those, get your ECU reprogramed for your compression and you're good to go. : ) Good luck!
kilipo4
Ya, I've got the DE. It's a 1995.
