engine mods
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
Doomburger
Car: '86 Nissan 300zx
I wanna swap a vh45 with VK heads into my z31, but I can't find anybody that makes aftermarket parts for this engine. What do you guys do for performance? Cams, pistons, oversized parts, etc. ?
Raxephon
Car: '04 RX8...for the moment...
Time to start doing some reading
Step#1: Start here--> zeroforum?id=177
Step#2: Scroll to the bottom, select "all" in "Date Range", Read until your eyes bleed
Step#3: Once the blood dries enough to see again,Go here--> zeroforum?id=24
Step#4: Repeat step #2
If you go by the abbreviated version, you'll miss out on a lot of good stuff, take your time and enjoy the wealth that is NICO.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Allow me to be the devils advocate: Why would you want to put VK45 heads on your VH45?
Raxephon
elwesso wrote:Allow me to be the devils advocate: Why would you want to put VK45 heads on your VH45?
(Sorry, I've been dying to use that icon )
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Especially since the camshaft drives are totally different.
Lack of research here.
Doomburger
Well,I heard that it's a mod that people are doing. supposedly that, combined with headers and a decent intake should produce close to 400bhp
elwesso
2007 BMW M Coupe
id like to see some more information about this...
RobertsnewQ
I heard this from a local race shop, too. THey said their engine builder built a VH45 block with VK56 heads for a land speed car.
I didn't believe it, but it's the second (and this is the third) time I've heard it.
Wish I had a VK head to play with...
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Compare valve area. But the VH45DE is larger.
VH45DE: Intake: 38mm Exhaust: 33mmVK45DE: Intake: 36mm Exhaust: 31.2mm
Intuitively, it seems silly to put a head designed for an open deck block on a closed deck block. Then there are the drive chain laybout.
Urban myth? Let's see the data.
Falkdesigns
Car: 1998 Q45t ~ EXE
I know in the land of Honda, it's very common to do head swaps, like a B16a head on a GSR bottom end. Totally different, but the same concept.
elwesso
2007 BMW M Coupe
now VK56 head would be COMPLETELY different than a Vk45!
Q_SHIP
Car: 1999 Q45T with a billion miles.
Falkdesigns wrote:I know in the land of Honda, it's very common to do head swaps, like a B16a head on a GSR bottom end. Totally different, but the same concept.
Yeah, even the old Pontiac Big block guys used to do it. 400 heads on a 455.
defrag010
or like bolting some 305 chevy heads on a 350 for higher compression....
Q45tech
The last American V8 that had much in common with a Q45 [until the 90's] was the 1964-67..... 273 Dodge Dart GT V8 engine and that was in displacement only.
Heads don't swap in V8 Japanese engines [Toyota nor Nissan].
elwesso
2007 BMW M Coupe
What about the northstar?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:now VK56 head would be COMPLETELY different than a Vk45!
Don't think so as a VK56 is just basically a stroked VK45. Why rpm peak drops so precipitously.
I would be real surprised if cooling passages matched between an open deck and closed deck design.
It's rather discouraging board non-Australian speedboating members don't recognize what an exceptional engine the VH series is, especially the VH45DE.
The American and Honda blocks are all basically the same design, with the same top mating surfaces. Ancient cam in blocks with pushhrods or OHC cam actuation via belts make adaptation easy compared to adapting chain driven camshafts of differing designs.
Modified by maxnix at 10:09 AM 4/11/2006
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:What about the northstar?
What about it? Good attempt, but block is fragile compared to most German and Japanese designs.
Doomburger
alot of people on automotiveforums.com are talking about vk head swaps, but I don't think that website's very reliable.
elwesso
2007 BMW M Coupe
maxnix wrote:Don't think so as a VK56 is just basically a stroked VK45. Why rpm peak drops so precipitally.
I was just stating (not that I think its a good idea by any stretch of the imagination) that if you had to chose, the 56 would be the way to go... I agre with you though, why try and change a piece of engineering masterpiece with a thing that is much inferior!
The later northstars arent really "fragile" at all.. The redesign in 1998 and 2000 really helped any issues with the HG... other than that, its a strong engine... I sitll agree though, that it will not be able to handle increased power and RPM like the VH45 et.al.
Rex
Car: None
Doomburger wrote:alot of people on automotiveforums.com are talking about vk head swaps, but I don't think that website's very reliable.
I wonder if all this "talk" is really about VK45 & VK56's not VH45 & VK56's?
Just a thought.
Doomburger
That's what it's about, vh45's with vk series heads, I'm not quite sure weather it's vk45 or vk56 heads, but I'm pretty sure they're both the same.
one ton garage
Even if such a head swap was possible, i can't help but think that the costs and time and effort involved in relation to the benefits gained would be minimal compared to just investing in some other add-on mods on a stock motor... even something as simple as NOS
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
Can anyone guess if this is an open-deck design or a closed-deck?
sijoko
An interesting note about the VK engines: They do not have hydraulic lifters such as on the VH45DE. They use shims to adjust for valve lash.
The VK45 doesn't rev as high as the VH45. So why the change?
Is there any good reason to get rid of the hydraulic lifters? Seems to me that Nissan is trying to save money again.
Q45tech
http://www.planetsoarer.com/ca....html
SC/LS400 shims.............precision is the name of the game.
TgduMg
Car: 94 Q45, 02 Maxima SE
sijoko wrote:An interesting note about the VK engines: They do not have hydraulic lifters such as on the VH45DE. They use shims to adjust for valve lash.
The VK45 has hollow camshafts
The VH45 camshafts are ?
Danisiti 1
Return to “VH45DE / VK45DE / VK56DE Forum”
