scream240sx wrote:im about to start making modifications to the engine and just wanted to know what yalll think about the setup i wanna do. tell me if i should change or add anything to it. i plan on running mostly nismo except for certain things they dont carry.
hot shot intakehot shot headernismo exhaustintercooler kithigh perfromance cams and shaftracing clutchturbo kit or nos
Well.... if you are debating putting in a turbo... the Hotshot header and intake would be pretty much useless.
I wasn't aware NISMO made an exhaust, I guess you learn something new every day.
An intercooler would also be useless without a turbo.
"High performance cams and shaft" sounds like a good idea, what kind shaft(Drive, cam, half(output), crank)?
You can do N2O no matter what setup you chose.
