Did you notice the same hesitation anytime while driving as well? Like pulling up a hill? I wasn't sure if the IAC controlled anything other than idle.jux wrote:Went through similar issues with my 237K pathfinder a few weeks ago. The idle was rough after warming up, turned out to be the idle air control valve however it did throw a code.
Leo1998 wrote:I cleaned mine backyard mechanic style so i wouldn't have to remove the intake manifold (it is under the intake on vg33 engine) What i did is pull the front hose ( the one going under the intake) off of the air/intake and poured/sprayed throttle body cleaner or similar down the tube until it filled up, reconnected hose and started the rig. May have to do more than once. You will see some smoke out the exhaust but it's just the cleaner being burned up in the combustion chamber. What happens is carbon builds up in the valve and it effects the "on/off" cycle of the IACV, so you are just trying to clean it out. Also clean your throttle body opening along with the butterfly plate by spraying cleaner into it and wiping out. Here's a youtube video showing the hose, the only thing i didn't do was do it while the rig was running, maybe better...Idk? I did mine kinda as a maintenance because it turned out to be my MAF sensor and the idle was doing way more crazy s*** than the hesitation you have.
http://www.youtube.com/watch?v=2wz70IEr2I0
It would stall occasionally but didn't notice serious hesitation. That happened 2 weeks later when my distributor decided it was going to join the failure club followed by an 02 sensor 5 days later.nutsaboutbolts wrote: Did you notice the same hesitation anytime while driving as well? Like pulling up a hill? I wasn't sure if the IAC controlled anything other than idle.
Leo1998 wrote:I think you may be on to something...Here's this http://www.nicoclub.com/FSM/Pathfinder/ ... der/ec.pdf
Page 581
and HA=19 http://www.nicoclub.com/FSM/Pathfinder/ ... der/ha.pdf
and your service manual to download http://www.nicoclub.com/FSM/Pathfinder/2000_Pathfinder/
If you get to the point you decide it's the bearings on the A/C compressor give a shot at replacing the bearing instead of the compressor. I would assume you have the same compressor I have (1999.5 vs. 2000) and if so you can get the bearing here.nutsaboutbolts wrote:Ok so I just ran 3 cycles of carb cleaner through the IAC with no noticeable change.
I am almost leaning towards an issue with the A/C compressor. As soon as I turn on the AC the idle gets really rough. Could the bearing be trying to lock up and adding too much load to the engine? I checked the pulley temp with no load and it read around 130 - 135 degrees. Once I turn on the air and load is applied the temp climbs up to over 200 degrees and holds.
Hate to bring this up but just because you removed the belt and the idle stays smooth doesn't necessarily mean it's the compressor bearing. By removing the belt you removed the compressor load so turning on the A/C does nothing as far as the engine is concerned. You could still have some other low idle issue that only shows up when the compressor is on because the engine has to work harder at idle due to the compressor load.nutsaboutbolts wrote:OK, so I am now positive that I have 2 completely separate unrelated issues.
I removed the AC drive belt - just to ensure when I turned on the AC that the rough idle was not coming from some sort of vacuum or electrical related issue. I turn on the A/C and the idle stays as smooth as silk. - Solution: Replace Compressor bearing or complete compressor if I find one cheap enough.
[/b]
