Engine Missing Then Overheating
goody90q45
Car: 1992 Infiniti Q45 (sold)
The Q has been having an overheating problem this summer on days over 100 degrees when I'm in stop and go traffic or sitting with the engine idling. It will start to miss for about 30-45 seconds and once the miss goes away the engine temp starts to rise but never makes it to the "red" zone where it cause damage to the engine.
Previous owner replaced the water pump twice and I put in a new thermostat at the beginning of last summer when I bought it. I replaced the fan clutch after the first overheat and did a chemical flush of the radiator after the second overheat and it's done it one more time. The service records don't show the radiator having been replaced but I don't have this problem unless it's over 100 degrees.
Any ideas why the engine miss followed by overheating?
Skibane
Car: 2000 Q45 AE 110K
Off the top of my head - An overly lean mixture will cause misfiring, and also makes the engine run hotter.
Vacuum leak, maybe?
Have you scanned the ECM for any codes?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Honestly I wonder if the overheating is causing the missing, and not the other way around.. Remember that when the ECU reads coolant temp above 195°F it starts pulling timing to try and cool the engine down, so perhaps this is what is causing the rough running and whatnot.... The gauge inside the cabin doesn't react as quickly as the temp sensor for the ECU. My point is, I bet the engine is overheating before the temp gauge reflects it.
I would suspect the radiator personally, and replace it with one of those nice CSF all-metal radiators.. :)
Q451990
Ditto on what Wes said. You need to be able to see the actual temperature with Consult or Consult software...
Heath
db_autotek
Car: 1994 Q45t black & 1993 Miata racer. Previous: 1994 Q45, 1992 Q45.
It also seems very unusual for the prev to have replaced the water pump twice. Once I can totally get, but a second time seems odd. I do notice the Q's I've had generally start running poorly above 100 deg days (which is a lot of days on S Florida city streets). I deduced it was a function of timing retardation combined with the ethanol, on top of that you have CA fuel :/ A cheap and informative thing is to try a good ol radiator flush, see what comes outta there. Chunks, rust, metal, whatever.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Was the fan clutch OEM? Can you hear the fan roaring when you rev the car when its warm? Do you have the engine splash shield installed? Do you have the A/C on while its overheating? (My Q's A/C doesn't work!, So maybe a dumb question).
