engine missing
JPG0511
Car: 1993 240sx fastback
I have had my 93 fb for about a year now and it has always had a very small mis at low rpms and accelerating slowly. it almost seems like it is not missing but it just doesnt make the power it should. once you get on it and the rpms get above say 4000rpm you can feel the engine making more power like it is a vtec. and it seems to be running a little rich. i have done a complete engine rebuild/tune up about 1000 miles ago and checked the egr valve. it does better but the problem is still there. oh yeh it seems worse when it is cold. it is really starting to get on my nerves. i am thinking maybe the coil or distributor is going out. has anyone had this problem? sorry for the long post but any help will be appreciated.
robbbby
check cap, rotor, wires, plugs, plug gap, timing, etc.
JPG0511
all changed and the timing has been checked
robbbby
And you're still having the problem?
JPG0511
yes
burnin240sx
topic: engine missing
what do you mean the engine's missing? it didn't jump out and run away. someone must have stole it.
s13EastTN
Car: 91 s13 hatch, 95 Honda Civic
Low rpm missing could be tons of things. Mine does the same thing, I think its a sensor making it retard the timing. Try advancing the timing a little bit, and see if that helps any, if it does, then maybe its being retarded for some reason, if it doesn't help, then its an ignition system problem(probably).
DRFT24O
Car: 1991 240SX Fastback
check your compression?
JPG0511
yes it is fine. it was a little low before the rebuild but fine now
DOOM240sx
Car: 93 Hatch too Custom 4 u
i had a similer problem...i got rid of the AIV and the O2 sensor, bolted on a header and BRM 2.5" exhaust and it's solid now. however timing is criticle experiment with it a lil.
DOOM out.
