mottabam »
https://forums.nicoclub.com/mottabam-u37104.html
Tue Mar 17, 2009 1:04 pm
1993 240sx convertible 136k miles all original no mods I'm the only owner. Car developed a miss only after warm up and only when idling or at a stop. Drives fine otherwise. Engine rpms go down and a slight shake and slight exhaust sputter. Have replaced plugs, cap, rotor, wires, intake manifold gasket. Checked MAF, Injectors, Motor mounts, EGR valve all fine, compression is normal. Still same thing. Cold start runs fine, once warm the miss at idle. Any help is appreciated, about to throw in the towel.
