Recently got a 2011 m37 and was getting a p0305 code. Changed out the spark plugs and now I have the p0303 code. I am assuming this means the my ignition coil is probably the culprit, as I am pretty sure I used a different coil on all the plugs. (Would love if someone could confirm please!)
My question is regarding the correct ignition coil placement. My manual does not specify the correct order. Is there anywhere a diagram is available?
Thank you!
