Gino »
https://forums.nicoclub.com/gino-u21116.html
Sat Dec 09, 2006 1:26 am
as for th injector clip, if the plastic around it is breaking (Which is common for our cars, seeing as how 10+ years of heat gets to the connectors and makes them very brittle *another excuse for a nice vented hood lol*) as long as the connector is down enough to be making a positive connection to the injector, you should be fine. Make sure all your connectors are clean and down as far as they can be. If the clip is bad enough that it wont stay down, then yes buy a new one and splice it in (solder it dont just use crimp connectors and half *** it). As for the EGR, like brad said, without pulling the motor the EGR is a ***** (even with the trans pulled). I havnt seen many (if any) EGR problems either...
