engine messed up
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
yesterday when i got off from work at about 9 30, it was pretty cold around 32, i started my car and let it warm up for a min or two, then drove slowly still letting the car warm up, but after like 2500 rpmmy car would just totally like bog, i'd have the pedal down to the floor and it would slowly accelarate, going slowly trhough the rpm range, and even after it warmed up, and the whole day today. Does anyone know what the probolem could be?
Thnx in advance
Hijacker
Car: '92 240sx Convertible
'94 F-150
is it an auto or a manual?
Nitrus0nous
I have an auto and it does the same thing. Only mine is not a everyday thing. Some days it does it, some days it doesn't. Its only from 2500-3500rpm, before and after is fine. power seems really low, struggles to climb rpms. except for a little hesitation off the line unless you give it a lot of gas.
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
its a 5spd, and mine use to do the same thing as yours nitrousonous but now it does it all the way up to like 6000rpm
rschwalbe
Car: Weightlifting and my daughter
From your descriptions, mine was doing the same thing and is now so bad I can hardly drive it!! REad my other post!
Chingon
Car: 1991 and 1992 hatchbacks
how is the idle? I've had a similar problem with a rough idle. Usually something in the fuel line or dirty injector. A bottle of seafoam fixed it once...and another time, I just pushed it to 55mph...and it got "unstuck"
rschwalbe
I'll try the seafoam--just did that a couple months ago as well. And the injectors are only about a year old. Replaced the stock ones with Pythons last year.
Chingon
I think our tanks need to be cleaned....they are nearing 15 yrs you know..?
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
i ran seafoam through the brake booster like a week ago
Chingon
run it through your tank.....injectors won't clean through the booster.
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
kbut when i ran it through the booster no black smoke came out, does this mean my car had no carbon build up?
Chingon
I only had white smoke....so I guess there are different "levels" of carbon buildup.
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
i had like no smoke at all, it was all normal
