With a stock ECU tune like Enthalpy's it will only pull a set amount of timing based on what you tell the tuner your max boost will be. If you plan on cranking up the boost past that, you will need a new tune, or a reflash.
eazye2000 wrote:To an extent. It wont pull anymore timing that it's told to reference off the tables.. Which is there because you told the tuner what parts you had. So if you add more air/boost, it won't pull anymore timing and BANG.
This isnt true at all. Every MAP based ignition tuning system runs RPM vs kPa values, just like the fuel table. So it works the exact same way, IF you have your values set to accommodate the extra boost(for the extra needed retard in the timing). If not, it will just extrapolate the values that are outside of its bin.
Megasquirt is a pretty serious ordeal. If this is your first turbo project, i wouldnt recommend it. People have had some good success will MS1, but MS2 is still being a PITA for everyone who trys to use it. Not saying dont use it, but i learned from experience. Bought MS2 and had my car down for 3-4 months while i messed with it. After it fried a chip on the board and killed my starter, i switched to an Enthalpy... I have yet to hear of one success story for MS2 and the KA dizzy. So if you do decide to go with ms, go with MS1.
