Engine Management
Foxtrot
Car: 1992 Nissan 240 Sx Se
was wondering if there was a good engine management system that i could upgread mine to was thinking of trying to get around 500whp out of my ka and i am rebuilding the bottom end at the momant and i was wondering if any one could sugest a few standalone systems or a few add ons that would help me acheve the 500 whp
CleanSfourteen
Car: A cooler car than yours
Welcome to NICO,
Are you boosting this built motor? and if so, with what? Cause i don't see you even getting near 500whp withsout some kind of forced induction...
Foxtrot
was thinking of using the AMS GT35 ones i got the engine build because of the quick spool it has. and thank you for the Welcome hope to learn alot here ^^
S0lid_Snake
Car: shopping for a car
Welcome to NICO foxtrot!the GT35 will definetly make that kind of power, but it doesnt have good spool...
AMS.com wrote:This turbo will reach full spool on KA24DE between 4000-4500 depending on your setup.
that said, i dont think this would make for a good daily driver turbo, better off using the GT32 imho. good luck with the boosting though, good to see KAs making big power
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
Welcome to NICO.
The best thing for you to do is read. Just browse the site, use the SEARCH button to answer any questions you may have, and if you can't find the answer then make a thread. I've been on this site for over 2 years and the information exchanged here is endless. Do your research, then come up with a plan on how you are going to hit 500hp.
There are many many different choices you can make regarding engine management. You can do anything from have your stock ECU chipped to using a standalone like AEM EMS, but whatever you choose to do remember that a good tune is the most important part of building your car.
What year 240 do you have, and what did you rebuild the bottom end with?
Jookmasta
the gt32 won't support 500hp but i think very few turbos exists that will give you the spool of a gt32 and are capable of 500hp without costing double of what a gt32 will cost.
welcome to NICO and man your gonna have countless hours of reading on this forum ahead of ya..........
elpiar
Car: 1992 KA-T
what piston and rods are you using? what cr?
Craving4Boost
Car: 91 240sx fastback
S0lid_Snake wrote:Welcome to NICO foxtrot!the GT35 will definetly make that kind of power, but it doesnt have good spool... that said, i dont think this would make for a good daily driver turbo, better off using the GT32 imho. good luck with the boosting though, good to see KAs making big power
for a turbo that is capable of 600hp, 4000-4500rpm is good. I would not call that lag at all
