Engine Management System
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
nErdsa_guy
Car: 2009 Versa
Ok gang I am looking for a Versa engine management system. I know there are supposedly couple universal systems (AEM F/IC and the Osiris) but are there any Versa specific systems? Here is the deal, I found a shop here in Denver (where after several months of moving all over the country I have finally settled) that will build a custom Turbo kit and warranty the work but ONLY if we can find the above mentioned system. He doesn't want to install something that he can't look me in the eye afterwards and feel good about (I respect the hell out of that). So I am on the hunt. If no system is available then no turbo. Let me know if anyone knows of anything, or if anyone knows more about the Osiris or AEM systems (only one shop in all of Colorado will tune the F/IC system by AEM).
Thanks guys.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
I don't know of any Versa specific EMS systems, but something that can run a 350 or 370Z may be able to do a Versa system also.
silverarrow27
Most if not all true EMS are universal.
Try checking with Nistune.
Disphunktion
Car: Nissan Versa
back in the day when I was running a turbo on my GTI 16V, I was using an SMT6 which is a piggyback to drive 1 or 2 extra injectors.
here is the link of a newer version : http://perfectpower.com/products/smt8.asp
By doing that way, anyone that want to reverse the process of installing a turbo or a supercharge could do so. The only thing is, they will have to provide a goose neck to fit the two extra injector.
PS : If not there is also split second that does the same kind of setup (http://www.splitsec.com/products/aic1/AIC1.htm)
westpak
Car: 1971 240Z - 1990 300ZX TT - 2003 350Z
Not sure what you mean by universal, but the Osiris gets as specific as it can get, it actually tunes your ECU, been using it on Z's, G's Xterra's and Titans for years both NA and FI
Return to “Versa Technical Discussions”
