the emanage has both injector and mass airflow correction features to automatically calculate the new settings for timing and fuel if you were to upgrade hardware. fuel will need to be re-fine tuned just as it would with any standalone, but timing will be set.bruinbear714 wrote:Using SAFC/Emanage will work for low boost, but as soon as you change your injector size and/or maf, you will need to retune your whole ignition map.
