hhawa wrote:well, I went and got some fuel cleaner in the car and engine cleaner. After two days, and I dont really drive too much, after half a tank of new gas, I was not able to notice the noise when driving tonite. I hope its fixed, not really sure, I floored the car beleiving the more gas burnining, the cleaner it may be. Question for you...do you think that the cleaner works overtime or should it have worked instantly.
If you use an injector cleaner (like the BG44K), it can take some time to clean things out.
My approach is start with a low amount of gas, add the BG44K while at the gas station, fill up immediately, and go for a long drive. Like a quarter-tank worth, if you have the time. But, this is not strictly necessary per se.
Glad to hear that things are improving for your situation.
Z
