Checkered-Member »
https://forums.nicoclub.com/checkered-member-u10193.html
Wed Aug 17, 2005 10:46 am
Machining the Cams is a waste; the KA cams don't have THAT much overlap so don't bother.
Port the intake mani is always a good idea, removing the secondary butterfly system will give you better flow top end, but you will loose some low end tq, it's a trade off/balancing act, most people had it done with good results.
how about a Bigger throttle body?
About the valves, you can buy already polished oversized forged valves, seems like a better alternative then the one you mentioned.
Cleaning the block I assumed it will be hot tanked?
All gaskets should be replaced, and I mean ALL gaskets.
About the rods, if he can guarantee them in writing that they wont fail for at least one year, go for it, if not, why risk it?
