94_240sx »
https://forums.nicoclub.com/94-240sx-u26401.html
Mon Sep 27, 2010 11:39 am
If your tires wear out evenly, do the balance first, not the alignment. If engine works fine, don't do anything for now. Fix it if it breaks. I had all the problems at the same time, but I fixed them all and it runs like new now. Mine has 150,000+ miles and things went bad in this order.
- Removed upper chain giude: It started making rattle noise.
- Engine front seal: leaked like crazy, so under side of the car was completely trashed.
- Injector #1, #2, & #4: Car shook like crazy suddenly.
- Water pump: Car was in the garage and out of nowhere coolant was leaking under the pump. Replaced thermostat as well.
Replaced rear engine seal when I did the 5 speed swap and had just usual maintenance stuff like synthetic oil(Mobil 1), plugs and wires. Seems like my KA will run forever.
