Solved: Engine Loses Speed/Power on highway @ 50 mph
mister ed
Car: 1994 Nissan D21 Hardbody P/U KA24E engine
I have a 94 Nissan D21 w/ KA24E engine that has started to intermittently lose power out on the highway. Typical event: 50 mph, level road, 4th gear, 2 wheel drive, vehicle slows to 40 mph or so and does not respond to depressing accelerator pedal. I know the EGR valve or vacuum line is dirty/needs replaced as the check engine lite goes on and off because of this- verified code on computer monitor unit.
I have eliminated the catalytic convertor and fuel filter as possible problems.
Is the next logical step to look at the fuel injection pressure regulator or the fuel pump?
I don't presently have a gauge to check the system fuel pressure. It starts, idles, and accelerates fine.
Truck has about 190K on it. Original owner.
Troubleshooting advice is appreciated. I do have a Chilton's Manual for reference.
Razi
Car: Moo
Figure out the issue with the EGR and vacuum lines.
I believe you can buy or rent a fuel pressure gauge at Autozone. Shouldn't cost that much.
mister ed
After 300 miles the truck has not repeated the problem. Hopefully changing the fuel filter has fixed the issue.
Razi
Car: Moo
yay!
