angelm231 »
https://forums.nicoclub.com/angelm231-u144754.html
Thu Nov 26, 2009 12:50 pm
Ok, here's the scoop and a quick recap. I took my 01 Pathfinder in to have the exhaust cover tightened. When they were done the engine light was on. The code said air in line so tightened gas cap. Light went out for 5 mins then came back on. A different code and they wanted nothing to do with it. So I took it to another mechanic, a more reliable one. He ran a diagnostics and it said the same as the other one...it was the intake timing selenoid, bank 2. They changed the intake timing selenoid, engine light went out for 5 mins and came back on AGAIN! I had no money left so another diagnostics has to wait. The mechanic noted on my receipt that 'other selenoid and 2 sensors compromised.' I have NO clue what this means...but my question is this? Is there a wire or plug that could have come loose when they tighteded the exhaust cover that could be making the engine light throw out all these different codes? The mechanic did say that when one selenoid goes out another, or even all of them, will come up on code and need to be replaced. Is this correct? Please help! I don't have money to keep replacing parts!
