zilla19 »
https://forums.nicoclub.com/zilla19-u119243.html
Fri Dec 19, 2008 8:20 pm
I'm assuming you meant SES light. It doesn't remind you of oil change. Go to Auto Zone and have them give you a free check on what the OBDII code is so you can have an idea of what's wrong. I was gonna do a search and give you the link to one of the posts on how to check the code yourself but apparently the search icon disappeared. I'll try to summarize:
1. don't step on the brake, press the ignition twice to "on"2. wait 3 seconds and then depress the gas fully 5 times within 5 secs3. wait 7 seconds and then depress the gas fully and hold it for 10 secs4. the SES light will start to blink slowly, count the number of blinks before the pause, that's the number (10 = 0)5. the 2nd, 3rd, and 4th set blink a little faster than the 1st set6. once you have all 4 numbers, do an internet search and you can find out what it's for, or you can go to Auto Zone as stated above and have them do it for free with a print out result
You might have to try those steps a few times before you succeed.
