ou1848 »
https://forums.nicoclub.com/ou1848-u1534.html
Wed Oct 30, 2002 8:57 pm
I'm sorry this is pretty vague and useless I'm sure, but on the ECU, on the opposite side from the wiring harness, there is a little diagnostic light that you can see through a hole in the computer casing. You need to double check with a mechanic but I believe that you can use that light to diagnose the problem, and also there is a way to reset the ECU back on that side. (this is IF the 24hr thing doesn't work).
seems like an awful long time to disconnect the computer.I've heard of hondas and stuff for like a few minutes, but if it works....so be it
good luck
