i forgot what plugs, but i picked up oem from nissan, i redid my timer and had autozone clear the code and it hasn't come back yet. neither has the cat code. ill let you know if it does come back, i still need to change out the cat thoFull Street wrote:What type of plugs are you using?
Well just like every other code, its not telling you what is bad, its telling you where the problem may be. The knock sensor code doesnt mean that your knock sensor is bad, it means its detecting knock. It could be phantom knock from exhaust leak or exhaust bumping arround or lifter tick/valvetrain noise. Definately check your timing. Also try throwing in some premium fuel and seeing if it goes away, if so, its not phantom (fake).
The cat code could be a bad rear o2 sensor, or a faulty catalytic converter, it wont just go away by clearing the codes.. Let us know.
Also is it misfiring at all under acceleration??
