1red240sx wrote:I own a 91 240 recently converted to a 5spd. Ever since then the check engine light has been on and when I took it to my mechanic, he said it would always stay on since my transmission was from CA and my KA 24DE is from Florida and its different emissions. He even changed the O2 sensor but it didn't help. I had my smog check 2 like a month ago and it passed with flying colors but since the light was on, it failed visual. I came home and took out the light bulb and when I had it re-tested they failed me b/c the CEL (check engine light) was supposed to come on when you turn the key to ACC so in turn he failed me too even tho the engine passes. Now when I talked to my friend on Friday night, he told me I can cut the CEL wire in the harness and splice it to the oil light. I did that about an hour ago and the CEL still doesn't come on when in ACC and the OIL light stays on when the engine is running. what can I do to have the light come on when I turn it to ACC and for it to stay off when the car is running so I can get my certificate. I look forward to hearing from you because I got to leave later on today and don't have the longest hours since I work in the afternoons. let me know.Garrett
Sounds like you're driving a POS. Oh, and splicing the harness is never a "fix". The only situation where it's a good idea is when swapping engines with similar harnesses or ones that can use the same ECU with minor changes.
You should also be warned that if you've disabled your CEL and sell the car, and someone finds out, there's a fine involved. You can also lose your right to sell cars, but that's only for dealers.
Also, sounds like your smoggers and the mechanic you've been taking your heap to are morons. The CEL check is when the engine is in the "ON" position, there's no need to have a light in ACC. Secondly the trans doesn't have an emissions-related sensor on it, far as I know. You should just be able to change the speed sensor.
You don't seem to want to hear "take it to a tech" so i'll improvise.
Take it to a GOOD tech. Maybe the Nissan dealer, if they're fairly reputable. Also, tell them about the trans. Stop trying to fix it on the cheap, get it done right or take it to the junkyard instead of butchering the harness to try to cheat your smog check =/
Or...you could always put the auto back in for the smog test, heh heh. I suspect they won't care that it's got a clutch master, so long as it passes properly.
