S12-Tengoku-Rally wrote:Well from what I heard the owner kept in good condition and in a garage.
Around here "garage kept" just means it wasn't parked outside, which is good. 130K on a 20 year old car is pretty low. If that means it was driven consistently but very lightly that's excellent. If it was driven back in the 80s, sat for 10 years and was recently put back into use, there may be some maintenance work you'll have to deal with.
Have you had a chance to look under the hood? Look over the hoses and such for dry rot and cracks. If you suspect it may have been sitting for an extended period check the coolant for rust. Neither of those indicate a bad motor; they're just indicators of a car that's been sitting awhile or has been poorly maintenanced.
Give us a bit more info on the condition of things and we'll be able to help you better.
