JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Sat Sep 21, 2002 8:29 pm
Yes, all of these would be the problem.
1) Temp sensor: located between the intake manifold and cylinder head near the front of the engine right behind the power steering pump. If this sensor is bad or disconnected the ECU will think the car is cold and dump more fuel than required into it, even if its warm. Check this first. Unplug the sensor, if it is green on the inside of the connector, replace the connector. Unfortunately Nissan doesnt sell the pigtail connectors by themselvs; you will have to go to the junkyard to find one, but it doesnt even have to be the same year or even the from the same sensor. Any pigtail that style will work. Solder the new one in (butt connectors dont work worth a fart in this application).
2) O2 sensor: if your car is running super rich from the coolant temp sensor being out, this will cause this problem. You will likely want to replace your O2 sensor after you fix your coolant temp sensor. Easy easy stuff.
3) Throttle position sensor: man i wish i could tell you, i have yet to have a problem with mine. I do know that if the sensor if off, it will tell the ECU that the car is at wide open throttle (WOT) even when it is not, therefore bypassing the O2 sensors input and dumping boatloads of gas in once again.
Try the coolant temp sensor/connector then reset the ECU (unplug the batt for 20 minutes). If this makes it run better, then change the O2 sensor (the old one was likely fouled pretty bad before), reset the ECU again and check your codes. Hopefully this will solve it.
Good luck!
