Engine Knocks at Idle when Hot
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
conversation
Car: Versa 1.8 S HB
After the engine warms up, it has a slight knock when it is idling. Sometimes you can feel it shaking the car just a little, too. It doesn't happen all the time.
Only has about 8,000 miles on it. 1.8 hatch back Versa 2009.
I changed the oil and filter at 3,600 and 7,500 miles.
Cars runs OK otherwise.
jwerty1
Car: 08 versa sl cvt blue, 08 frontier se 4x4 kingcab 6sp storm gray
probably a non issue as these are noisy motors, keep tabs on it, maybe document it with your dealer, keep doing your oil changes on a regular basis, if there are any issues, your motor is under warranty for another 52k miles, plenty of time for a real problem to show its ugly head, but I wouldn't worry, it's probably just normal
Return to “Versa Technical Discussions”
