Engine Knocking
blueslate37
My G7 has developed an engine knock. When the knocking starts my car wants to idle at 1100 + RPM's. Went to the dealer and they said ... yep you got a problem and we know about but their isn't a fix yet. Oh and don't worry it doesn't hurt anything. I was told it's in the WEL valve setup, which I might agree since it sounded high and to the rear of the engine. One thing that bothers me is I've never noticed a knock that didn't harm anything, .... I mean two pieces of metal are hitting each other!
TeflonG35
Car: 2003 G35 Sedan
The car is under warranty. You will be fine.
SneaKe
Car: 2006 Infiniti G35 6 ManTrans Coupe Ninja Turtle
TeflonG35 wrote:The car is under warranty. You will be fine.
Agreed.
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
a Knock is when the piston is in the compression stroke of the motor and the spark plug fires too soon and the piston (even with the combustion occurring) has to finish the compression stroke hence a Knock
This is never a good thing and can occur by changing from 93 octain to 87 or vise versa.
what type of gas are you using.
But what the H ell you have a it covered because it is new!
DJ
telcoman
blueslate37 wrote:My G7 has developed an engine knock. When the knocking starts my car wants to idle at 1100 + RPM's. Went to the dealer and they said ... yep you got a problem and we know about but their isn't a fix yet. Oh and don't worry it doesn't hurt anything. I was told it's in the WEL valve setup, which I might agree since it sounded high and to the rear of the engine. One thing that bothers me is I've never noticed a knock that didn't harm anything, .... I mean two pieces of metal are hitting each other!
Did you check the oil level. I don't think the type of gasoline is the cause if you are at idle. Pinging or knocking usually occurs under load.
Telcoman
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Telcoman
Yoda is correct.
Tampa G35 Sedan 6MT
Telcoman
Didn't even think of that!
Jacko3
Yep! It is under warranty. Don't worry, be happy! Check and change oil to premium brand, try another gas station such as Chevron use premium gasoline if you aren't), and then flog the car to see if it starts behaving well.
TeflonG35
Car: 2003 G35 Sedan
I really don't think flogging is always the answer. He didn't even mention if the motor was broken in yet.
