Mike G »
https://forums.nicoclub.com/mike-g-u62486.html
Wed Oct 31, 2007 3:33 am
Since you have no SES/CEL, I think it could be the knock sensor, seems I recall seeing they won't trip the light. If the sensor itself is bad, it will not retard any timing and knock. I would also look into cleaning off your MAF sensor before replacing it, it is an easy task. Check into the thread that refers to the 0171 code issue...
--Mike
