Kawabuggy »
https://forums.nicoclub.com/kawabuggy-u106499.html
Sat Sep 20, 2008 4:04 pm
Have an '03 G35 Sedan that we bought brand new. Currently has 70K miles on it. At 66K miles, it started pinging under light throttle when the car shifted into the higher gears. I did some reading and everything I read said to quit using the 87 octane that we have been using since the day it was bought. Well, we switched to 91 octane, and the problem did not go away. Last week my wife went to start the car and it started up, ran for a few seconds and then shut off. She restarted it and it did the same thing several times. She waited a while, and then tried it again and it started and ran normally, but set the SES light. I brought the car to work and scanned it and found P1121. This code is for ETC return spring problem as the description. I again went on-line and did some reading and everyone said to replace the throttle body to alleviate the knocking/pinging problem.
Update. Today I installed the new throttle body, along with a new gasket. I read about doing some type of re-learn procedure, but do not have a Nissan Scan tool. I also read that you could disconnect the battery, then after reconnecting it you should turn the key on for 10 seconds, and then off for 3, and repeat that 3 times. Well, I did that and now the car is not setting any DTC's. However, the idle is higher than it is supposed to be. This is causing all types of funky driving quirks. When I let off the gas now, the car feels like it is engine braking. You know the feeling when riding on a motorcycle and you downshift, let out the clutch, but don't give it any gas. Also, if I let off the gas for a moment, and then step back on it again, the car surges forward for just a second.
Anyway, the knocking/pinging problem seems to have diminished but is not completely gone. Now I have these other issues to deal with.
Can anyone tell me what you would do next? Please don't recommend going to a dealership as I will not do that. If it comes to a point where the dealership is the only place I can take it to get it fixed, I will sell the car as is.
I know there are some really good technicians working for Nissan Infiniti. However, it has been my experience that there is a very thick layer of BULL **** (Service Sales People) you have to fight with and rarely if ever get to speak to an actual tech. I will never under any circumstances deal with a dealer ship service department. Seriously, this car will be GONE before I do that.
With that said, if anyone has any ideas what I need to do to calibrate, or re-learn the ECM to work with the new throttle body, I would appreciate it.
Otherwise, if anyone knows of a Nissan/Infiniti repair shop in Houston, OTHER than a STEALERSHIP, let me know.
If it matters, I am a mechanic by trade. Old school type. Not great with electronics, but really good with the mechanicals. I can build engines, transmissions, differentials, transfer cases, and most other drive-line related items. If there are any techs in Houston that would like to barter services, I gladly offer my services.
